EQ's, pedalboards and the signal chain....
JamesL
Were do you guys usually put the EQ on your pedalboard?? Start? End? In terms of numbers and effects I go..
1. Fliters
2. Compressors
3. Distortion
4. Tremolo, Chorus, Flange
5. Volume pedals or mute switches
6. Delays and reverbs
so what number should I throw the EQ in at?? In between what numbers???
K
kreig
1 ,uno > everything else after
and then I use the controls on the amp for the finish.
Volitions Advocate
I always use my EQ as an extension of my Distortion.
So usually right after my dirt boxes or in the FX loop of my amp. right after the preamp.
mayfly
When I use EQ, it's in front of the distortion / compression.  JamesL's signal chain is pretty much what works for me.
stratplayer1
I throw my eq in right after the distortion, but my amp sucks so i really need it to be an aggressive shaper and boost, i think its more subtle if its before distortion, try both and do whichever you like better.
