DangerousR6 said:
				dbw said:
			Could you do very fine details like this?
I can give you a vector version in svg, pdf, or eps.
I'm afraid not, that's to fine a detail. To many little radius', I'd have to go thru each and every one and make sure the tool could cut each one. And that's way to time consuming, and I'm not afforded that much time. Sorry...
DangerousR6 i beleive the word is radii
and DBW yeah a design like that would be better etched onto a plate not cut into it, there are engraving tools that will cut very fine lines though.
look for a store that does custom engravings, they have cnc engravers that have a pointed diamond bit, the machines take vector drawings too. a CNC mill takes G-code which tells the machine where to cut. complex shapes are aproximated by
[size=10pt]breaking it down into short lines and arcs(very short)[/size] so you need to run it through a cad/cam program first to write the G-code. most cad/cam will import dxf, iges, and other common CAD formats, so you'd need a file converter that goes from vector to cad format, ive use stuff like this for doing plaques and stuff. some newer software has art features that can take common image files though. it depends on what you work with.
