TBurst Std
Every electric guitar/bass I have has Schaller lockers on it. Just a note to the wise, use lock tight on the nut on the strap portion of you have a thicker leather strap.
-VB- said:I usually make my own shims by cutting and layering pieces of paper to form a wedge of the desired thickness, but I decided to try out the pre-fab shims from Stew-Mac for this one. In typical Stew-Mac fashion, it was a bit spendy but it worked perfectly.
-VB- said:Once I got the saddles up at the proper height, I did have to go back and re-adjust the trem spring tension, cranking them down a good bit more to bring the bridge back down. Something something mechanical advantage something?
-VB- said:I found I was getting some sympathetic vibrations from the springs, so got very technical and stuffed pieces of foam between them.....
Cagey said:Another thing I've seen done if you'd rather not have loose foam bits in the spring cavity is stuffing lengths of surgical (silicone) tubing inside the springs. Not sure it applies here, as you've got a cover on the cavity.
Cagey said:There are arguments in both directions regarding saddle height. One is that you want the saddles higher to increase break angle on the string (pointless), the other is you want them as low as possible because it makes the trem feel "looser" (true). I suspect that as with most things, moderation is the key to happiness.
Logrinn said:Or foam inside the springs:
Another thing I've seen is, shrink tubing over the spring. Never had the need myself, but it appeared to work well. Sort of a home brewed version on these:-VB- said:Logrinn said:Or foam inside the springs:
Slick! I will remember that...
Cagey said:Turn it fully clockwise until the position indicator points at "11".
Now, THERE'S an idea! :headbang:Sovereign_13 said:Better put another pickup in the trem cavity and wire it into your output jack, just in case.
Cagey said:I've never seen a need, either. It's an electric guitar. Plug the thing in. If you can still hear vibrato springs vibrating, look for a knob on the amp that says "volume" or "gain" or something along those lines. Turn it fully clockwise until the position indicator points at "11". That should cover up any annoying mouse farts, feather drops, cat stares or spring vibrations that might be interfering with the quality of one's playing.
Cagey said:Nice work! Those came out well. My Photoshop skills are pitiful at best, mainly because I don't even know what the hell they're talking about most of the time. Rowing through the menus to find targets of opportunity for accomplishing different things is for me like trying to communicate with a Japanese in their native tongue using nothing but a Japanese/English dictionary :laughing7:
BigSteve22 said:Boy, that looks HOT! Great job Brother, really impressive. :icon_thumright:
Rgand said:Enviable job on the photos. Looks great.
Sovereign_13 said:Cagey said:Turn it fully clockwise until the position indicator points at "11".
But then you can't hear the built-in reverb that comes with your guitar. Better put another pickup in the trem cavity and wire it into your output jack, just in case.
