nathan a said:Man you guys are nuts, my sperzels look great! All i did was draw a line with a straightedge...
Orpheo said:nathan a said:Man you guys are nuts, my sperzels look great! All i did was draw a line with a straightedge...
what I do, is measure up exactly how far the pin should be from the big hole, and indeed, with a straightedge, draw a line.
SkuttleFunk said:Orpheo said:nathan a said:Man you guys are nuts, my sperzels look great! All i did was draw a line with a straightedge...
but then one man's perfection is another mans glaring mis-alignment. let me confess right here and now that I use a dial caliper to perfect the spacing and alignment of tuner keys. you may not notice a gap variance of 1/64" ... but I do!
all the best,
R
Orpheo said:SkuttleFunk said:Orpheo said:nathan a said:Man you guys are nuts, my sperzels look great! All i did was draw a line with a straightedge...
all the best,
R
just as straight as can be. its not rocketscience you know.
dbw said:This doesn't really qualify as a pain in the butt, but as long as we're all whining... I hate how GUITARS DON'T HAVE STRINGS when you're building them! Duh, you say, of course they don't... but I hate working without getting any feedback that what I'm doing is actually going to work. Maybe I should take up xylophone-making??
jackthehack said:Orpheo said:SkuttleFunk said:Orpheo said:nathan a said:Man you guys are nuts, my sperzels look great! All i did was draw a line with a straightedge...
all the best,
R
That's NOT the point!!! I used a T-square on a drafting table to draw my straight line. Of the three sets of Sperzels I installed ALL had at least 2 and as many as 4 tuners that had the guide pins off center enough to visibly cant the tuner off center and I had to remove them and widen the hole in one direction or another to get them all 6 to mount straight
RLW said:Well, for me, it's the body ferrules. Hour upon hour upon hour with tiny little bits of sandpaper, up and down, around and around, blow of the dust, test fit, yell at the dog because yet more needs to come out, repeat, and then repeat six more times. There has to be a better way.
At any rate, what's the one part of assembling a Warmoth that you dread most?
Rich
