dmraco
Master Member
ByteFrenzy said:While you're at it, could you fix the orientation? I didn't rent a pool to have the water look like it's standing straight up... :toothy11:
done...not sure why photobucket flipped your photo....
ByteFrenzy said:ByteFrenzy said:While you're at it, could you fix the orientation? I didn't rent a pool to have the water look like it's standing straight up... :toothy11:
:evil4: :evil4: Ok, you asked for it... now I have to post the pic of me IN the pool. :evil4: :evil4:
Mind you, it's six hours later so the tide has shifted and the water is oriented in the other direction.
EDIT: Thanks dmraco... a minor tidal wave and magically the waters return to their usual orientation...
exaN said:Thank you DMRACOccasion14:
I'm voting for pt's bass because I've never voted for a bass before and in all fairness it looks BADASS :headbang:
ByteFrenzy said:ByteFrenzy said:ByteFrenzy said:While you're at it, could you fix the orientation? I didn't rent a pool to have the water look like it's standing straight up... :toothy11:
NonsenseTele said:Voted for PT, that Imbuia top is amazing I wish to bad I could buy it, but I couldn't... Glad that you did it well!
PT said:NonsenseTele said:Voted for PT, that Imbuia top is amazing I wish to bad I could buy it, but I couldn't... Glad that you did it well!
Thanks Nonsense (I said it right this time)! Ken Warmoth told me that it is one of his favorite Brazilian woods and it smells good when cut. It is not that common of a wood laminate on this forum but the figuring is killer close up.
Bass-Adrenaline said:Since i couldnt find it anywhere what are the rules to enter a guitar in the contest?
Super Turbo Deluxe Custom said:Bare minimum a half-moth. A Warmoth neck and a non-Warmoth body or the other way around. To me it's tricky if the category is Warmoth finished and the guitar/bass in question is a non-Warmoth body with a Warmoth raw exotic neck. Where's the Warmoth finish there?
line6man said:The neck is a Warmoth, and Warmoth did the finish, but the epoxy was not done by Warmoth, and the body is a Squier. :dontknow:
ErogenousJones said:line6man said:The neck is a Warmoth, and Warmoth did the finish, but the epoxy was not done by Warmoth, and the body is a Squier. :dontknow:
So it's Warmoth-finished. No?
line6man said:ErogenousJones said:line6man said:The neck is a Warmoth, and Warmoth did the finish, but the epoxy was not done by Warmoth, and the body is a Squier. :dontknow:
The finish was done by Warmoth, but not the epoxy coat.
So the neck is like half-Warmoth, half-owner finish. Plus the Squier body, finished by Squier.
DesmoDog said:IMHO if the body or neck has a pro finish then it should be in the pro finish category.
tubby.twins said:DesmoDog said:IMHO if the body or neck has a pro finish then it should be in the pro finish category.
Agreed. So line6man should enter next time.![]()
