TonyFlyingSquirrel
Master Member
I don't use steel wool at all.
Too many particles to contend with.
If using Tru Oil or Poly, and doing a clear coat with no filler having already been applied, I'll use some 800 grit sandpaper with the first couple of coats to effectively wipe grain fill with it, then I'll start doing several thin level coats, sanding between every few of them. I'm not cheap with it, I'll get 10-15 coats on there to get a nice gloss by the time I'm done.
Then, fine grit by grit down to about 1000 grit, then buff/polish.
