rgand
Epic Member
After starting to buff out the clear on my Roadhouse body, I have realized that I need to put a better clear on. I'm thinking of going with Minwax Wipe-On Poly, which a test piece tels me will work over what is there already. I know thin coats are best and just keep building.
I can't find a good video that shows anyone putting it on a whole body, much less with a stain/finish on it. The most helpful videos have been someone putting the stuff on top of a guitar with square corners, some with binding but none on all sides of a body with a 7/16" roundover.
Does anyone have experience with this?
Specifically I need to know if I should put it on the top and let that set up then flip it and put some on the back. I guess the sides would probably get done with the top, maybe.
Also, how many coats should I put on before starting to level sand it. Not just scuffing but actual wet sanding. I'm a bit concerned about sanding through the color layers which are rather thin. I'm not going to be able to touch this up if I sand through so I want to get it right first off.
Lastly, what temperatures do I need to have to get the poly to cure properly between coats? Right now, it's 48° in my garage. I sure don't want to wait until summer for this but I will if need be. I can start my next project and get that along considerably before it needs a finish. Then I could just do both.
Thanks for any suggestions on this.
