Re-Pete
When you check out guitar repair and used guitar sites, quite often you see a certain brand of guitar starting with "G" being described as having a headstock repair.
Now while those repairs, if done professionally & competently will solve the issue, the original manufacturing has been found poorly designed with the headstock joint angle being the issue.
So, my question is, what IS the better angle other than 17 degrees?
