I conceived this project two years or so ago when I lived in central Texas and started making inquiries of various vendors and sources. I didnt have a trusted guitar tech but I happened upon a website for
Steven Robinson, of Manchester Guitar Tech. His website was impressive and I figured the shipping costs would be worth the added Sentimental Value and perhaps add to the romantic provenance of the build.
By the time I had all the parts together I now lived in Seattle, and had a wide range of craftsman available to assemble all the pieces, but I decided to stick with my original plan. I shipped the whole lot to England and sufferred the delay between messages, as now communications took place on a timescale more similar to if I were living on Jupiter than on the same planet.
Here are the photos Mr. Robinson took of the build, I believe I'll let his workmanship speak for itself. Some of the comments are his words, some are mine:
The kidney tuner buttons (which I scavenged off of the second set of tuners I bought expressly for this purpose)(nobody sells just the buttons in nickel plating)
juuust barely fit; if it turns out to be a pain I'll use the normal trapezoidal buttons. Nickel-plated Schaller locking tuners purchased from GuitarSupplies, a website based in the Netherlands.
Brass slotted wood screws. Of course, Steve pre-drilled the holes, as wood screws, while they give better purchase than sheet metal screws, also as a result are a bit more fragile.
Neck inserts fitted, showing screws cut to length to accommodate chamfered heel.
Neckplate fixed in place with slot-headed machine screws
The first plunge routing for the Trem-King TK1, polished nickel finish. These acrylic templates are available at Trem-King's website.
routing through the body
routing the tremolo spring cavity
Tremolo routs complete, need sanding
Tremolo routs sanded and given two coats of sealer
Trying the pickguard template for size; I worked hard on this custom idea for a pickguard, but my version was rough at best. I depended on Steve to polish its rough edges...
Bridge fitted with the E-strings to ensure everything lines up (very important, this!)
Control cavity shielded with copper foil to minimise interference
Tremolo cavity cover made from Tor-Tis, together with its template. Edges not yet rounded. These pieces of Tor-Tis I had Colette Hanson, owner of Turtleworks in Indiana, make herself. Calling her business phone is calling her home phone. In any event, I needed thicker pieces (not only for strength, but to match the thickness of the control cavity's inset) than were available from LMII, and I had some quasi-custom "looks" I wanted from the various designs she made available. She did fantastic work, mating the epoxy to an acrylic backing while fashioning them, in order to thicken it up. Turned out fantastically!
Tremolo cavity cover - trying it for size and appearance
Shaping the pickguard template
Pickguard routed, just the pickup rout and the roundover to do
Sanding the roundover on the tremolo cover plate
Pickguard in place - and it fits!
Electrics all wired with Varitone, phase and kill switches. The guitar has phase and parallel / series options, a varitone, and a killswitch on the final push / pull. It was an extra push / pull we ended up, and this was the best option to add some small extra utility. I imagine it will come in handy in the future. Pots by MEC, ordered from Banzai Guitars in Germany.
Had to modify the brass knob to get positions 1 and 4 on the switch, provided by Callaham Guitars. Knob made to my order by Armadillo Guitar Works.
Control cavity cover in place
Tremolo cavity cover in place
Everything assembled, just need to set up
We're finished - and relax!
I'm going to swap out anything phillips-drive with slotted-drive; as I have a fastener source, it will not be a problem nor delay for me to obtain them and I've asked Steve not to be picky about it. Also I will try out brass fasteners instead of stainless, to see if I can keep the motif going, or if it will be too much brass.
The MEC pots are solid-shafted, and as such require speed knobs fitted with socket set screws. The two colors available are black and white. I chose white initially (may try to relic them a bit with coffee) as I thought the guitar needed something bright to offset all the browns and beiges, but now I'm not entirely sure. I may swap them out with the black ones if the look isn't desireable when I see the finished product first-hand.
Next step is to cut the foam inside the case (I asked Tony Rimmer of Adrenaline Flight Cases not to use the Tele template but to cut specifically from this particular guitar and he generously agreed to do so), and then get the whole lot back to the States.
All in all I'm terribly pleased with the results so far. I put a ton of work into it and it looks like those I've paid in my stead have put in even more. Here's to serious craftspersons!
ccasion14:
