DangerousR6 said:I was thinking the same thing, just redrill for new pot and put a mini toggle switch, it doesn't have to be hooked up, unless you might want to split the hum... :dontknow:ByteFrenzy said:You don't really need the tone pots - a pot that's fully rotated in one direction can be replaced by a resistor of the same value.
A tone pot is just used to bleed the highs to ground by means of a cap.
As for moving the vol pot, you're not going to fill the existing hole without it standing out. That body's also far too nice for a PG. How about moving the pot and using the old hole to mount something else? A jack, or just the insert from a knob like you've got on there?
Yes,I might try this.I wouldnt mind being able to split the humbucker from time to time.
