Two in progress, Jazzmaster & Thinline
chriseragan
Just a mock-up so far.  Not everything is bolted down on the Jazzmaster, and the Thinline just got through with it's week of daily Tung Oil wipe-downs.
The Jazzmaster Peel and Play has a Roasted Maple Right Hand Reverse Jazzmaster Standard Thin neck from their In Stock.  Since the body on the Jazzmaster is a traditional Alder, I figured I'd go with traditional woods for the neck.  The body is chambered.  Pickups are used Duncan Designed I snagged off the interwebs, I plan on using them until I get a feel for the Jazzmaster, then I'll decide on something different in the future.  I do have Rosewood pickup covers on the way.
The Thinline is Mahogany with a Padouk top, neck is a standard thin strat neck from in-stock, Padouk with Ebony fingerboard.
56c6xUMH9sBYEgjag8WXuGiyBf994U0AmLRYmPelTe1_hJIr2eHqvAzYA2OqQHdnuoNFBcHYNY5IEXecB9DHWT7kRK-r8HE8sdqcr8h2wZX4sbNjo1AnSYj-Dfhd9OUD7B3Tc-OYOimCTmG9I-wE0y_yvjYkzyUTNMs3CSODOktUFSBlylUxj58d-8dWAajTIWZF79eMg8PyzBiUmwIZkcznMmsN392Caakt-gG-e7oI_qH25e-GLlZUtmiNSkJh2QUhMe0kTpEiAwQBBN-VjlcxFEgrT1hqQEVYxspquyUQ2MmlzL-auCHi-Rkpk0iP7H4AQGy1_v-oy1DfwGAzZc8LnICf53a9ZrMoWEyOdK-0cRFq5onx1aAfiuYQqUVFzKA0d9vRCvF-WYBxR7CqC9hoyUah5opSMU2aFdYKYx4x5tcwNEWxEDcOQNCqBzbs9rdDWa2vViPojvI2t8n9kSWzvvhb_nrMI_3HdxNZDtvNyTmlUPU_JPCwcmI5cL26wE1E83fzh5mPD1ywvqjOC3J-Z1J-T-zK4hjuXzDB2KdUQEGoFCH4k1-N8o6u9l-isZ0lq9osWla9qX86GO_faNDMwpEQ5QHTbirQleLk39z76pksNUgEV80JtS2dEzz2oKGvzdLPADuG4Tk0XHS71y6g8KkfAaWlu3ARus3WZuKX50UYZn2gIcjF=w568-h757-no
My thinline is meant to be a sibling to another thinline.
l4ul6e6w0U49bT7F9PE4_mstsBZFhgupbQyJ-WByy-QzfYOfYfDtv-vZI7ORUAXFKlTsYBwOctPOjgcSjkRqG-SxjUP9_D1q8HRRv_6Bp0-uhv1tjGVzSjafCG2PsxtJWO0Z-1L9_pqB1GQM9B3G-CIk-fIPNVH962FCpt6RnV7j_L25cxDO6gO-QTKqxmSSg26MmTNnmuqBtedCeDkZAX3173KT-nZ-x9Xavm6Dptglf2FsMYDP56_YwbGxEU9mShlbtDpzBYJcMrYZMhl0AfkcX36qwqQZZ5EvWgMJ2Dv3U1UgqREvGxMl1XnAP4xanomKYiDsttZDsPi4fLF3UV8EPA602Lo7b18EpMgd2VCDZLLc0QmrBhVSMOyQPBjSMbbcFGfiTbxE0ho9SSTL64H8iYY5WnMJzwZrH3dbuOitJpvxoKTSgYe83_ooIazLZkT7ly4ryUqdMy3iVz9mw1yxqQHtqU2DfWxczluhzU4c5Mywa_fReREAOcQO5q8y7lMF4GuFBVw1hWB-CzfRRL61r0FBizWZmfq5usmtM2qy9YZhMnutN4stoDqYx6OeASkA8Q_LfFdstlqprh-E19O5LIAgJhxuSxBeuuyxZXRlT4rYbcrDKjwgTelBsi5Oc-iAjDq9aqL5ihaoPbC0uUGGNI-kuezBufPVaa6V6pzLPmCROt1CJiIs=w568-h757-no
@chris:  In the context of a jazzmaster, reverse  headstocks are correct.  Like a rocket taking off!
Those show now. Handsome guitars. I like the way the headstocks go with the body finishes.
As planned....
On the Thinlines, the one with P90s has a Bubinga top with Bubinga neck wood.  On the one with Humbuckers, it's a Padouk top and Padouk neck wood.
And the Jazzmaster, Maple top, maple neck...
chriseragan said:
As planned....
Very well executed.
