Pre amp bias settings are a compromise at best, they are set so that the tube has maximum life, and that is about it. Tubes have many uses, if you study radios you get to realize why we had to get away from tubes and go solid state in most applications as tubes are at best a project of diminishing return, the very design of a tube is that it destroys itself. Such as the way they bias Amp tubes, so can you bias a preamp tube to get different responses out of it. I know each tube has it's perfect bias to idle correctly, but if we accepted that as a point to place it we mise as well accept generic products where ever they are available.
Look at the example I put forward earlier, Butlers Tube Driver, I love mine, great preamp before the preamp, now go to his site and look at the options, one is a biasing circuit for the tube. OK according to those such as -CB- we do not need to bias a preamp tube, and I am full of jibberish, but then if such is true why have power users such as Satch, Gilmore and Johnson all bought units from Butler with the Preamp Biasing feature in it? Unless they found out the tonal differences they could crank into it with the feature. Sure, go non adjustable, but would you not rather have the option if you could?
remember, besides a signal boost, preamps are all about shaping the tone.
A great example of notgoing by the book is the Blus Jr amp by Fender, the Bias the amp tubes real hot and they go through some tubes, that is why one of the common mods to the amp is to make the bias adjustable, so guys can make their tubes to last, but once you do that then you lose a lot of the sound you bought the amp for. Yea fender biases them hot, so what, and that relates to whatr I am saying about preamp tubes because, Like the Tube Driver, if you experiment around you can get real hot sound or a real smooth sound, I drop mine off.not increase them.
