mayfly
Epic Member
Jusatele said:I am not here to argue with you but you are over your head on this one with me,
wow - I'm staying out of this one!
mayfly said:Jusatele said:I am not here to argue with you but you are over your head on this one with me,
Superlizard said:Hey, imagine that - two people who disagree. The world's goin' to hell in a handbasket, I tells ya. :doh:
And I don't see any bitch-slapping yet. LOL
DangerousR6 said:Any noticeable difference that you can tell between them? My BS has Sovtek EL34's in it currently. I noticed a substantial difference between the E34L's and the Tung Sol 6L6's in the VooDoo. :dontknow:Death by Uberschall said:DangerousR6 said:I also have a matched set of JJ E34L's(not EL34's, but same type of tube) I had bought for the VooDoo, might try in the Blackstar when it's time.. :headbang:
The JJ EL34 and E34L are great power tubes. Got them in the Uberschall. :headbang1:
:icon_biggrin:Death by Uberschall said:DangerousR6 said:Any noticeable difference that you can tell between them? My BS has Sovtek EL34's in it currently. I noticed a substantial difference between the E34L's and the Tung Sol 6L6's in the VooDoo. :dontknow:Death by Uberschall said:DangerousR6 said:I also have a matched set of JJ E34L's(not EL34's, but same type of tube) I had bought for the VooDoo, might try in the Blackstar when it's time.. :headbang:
I tried two set of Groove Tubes EL34's, both times I had runaway current draw and blew the mains fuse. Went back to the JJ stuff and no problem. The E34L is supposed to have an extended bottom end when compared to the EL34.
What you waiting for???DangerousR6 said::icon_biggrin:Death by Uberschall said:DangerousR6 said:Any noticeable difference that you can tell between them? My BS has Sovtek EL34's in it currently. I noticed a substantial difference between the E34L's and the Tung Sol 6L6's in the VooDoo. :dontknow:Death by Uberschall said:DangerousR6 said:I also have a matched set of JJ E34L's(not EL34's, but same type of tube) I had bought for the VooDoo, might try in the Blackstar when it's time.. :headbang:
In due time.... :laughing7:Death by Uberschall said:What you waiting for???DangerousR6 said::icon_biggrin:Death by Uberschall said:DangerousR6 said:Any noticeable difference that you can tell between them? My BS has Sovtek EL34's in it currently. I noticed a substantial difference between the E34L's and the Tung Sol 6L6's in the VooDoo. :dontknow:Death by Uberschall said:DangerousR6 said:I also have a matched set of JJ E34L's(not EL34's, but same type of tube) I had bought for the VooDoo, might try in the Blackstar when it's time.. :headbang:
Jusatele said:so then you are saying there is no way to bias a 12ax7? no way in the world, correct?
http://archive.ampage.org/threads/0/ampdiy/012706/12AX7_Plate_Resistors-1.html
http://www.shine7.com/audio/12ax7_pre.htm
http://www.tdpri.com/forum/archive/index.php/t-114384.html
http://www.harpamps.com/micKqanda/What-is-Bias.html
http://music-electronics-forum.com/t17008/
http://gabevee.tripod.com/mysecamp.html
there is a huge difference between a fixed bias and not needing to rebias and being able to bias. Yes you can and manufacturers do bias preamps to where they want them
and you can easily change that bias or make it varible
Jusatele said:Ozzie, preamps do not amplify signal, they (for lack of a better term) shape it, oh they boost it to a level the amp can use, ut they do not amplify it. Yes when you adjust something other things happen, and is the argument to not have adjustments to the bias of a preamp tube, so that the manufacturer can sell a product that has a dependable output. You can see in different manufacturers that the way they approach preamp design which includes preamp cathode voltages) gives them the distinctive sound they sell.
http://www.ehow.com/about_5041020_preamplifier.html
