For preamp tubes, it really depends on what you're looking for and what position you're putting them in.
I think GT's descriptions of different tubes are actually pretty reasonable, so if you learn what other names those tubes go by (or learn to ID them by looking at pictures), you can go from there.
When I did a preamp tube shootout a few years back, I found this (some were GT, some weren't, but I use the GT names here):
12AX7-R (Sovtek 12AX7WA): Bright, a bit harsh
12AX7-C (China): Also pretty bright, but not as harsh; Usable
12AX7-M (GT Mullard reissue; seems to be no longer available; wonder if it's the same as the current Mullard-branded one's?): Slightly less bright and very smooth. My favorite of those I tested.
ECC83-S (Ruby Tubes/JJ): Fairly bright.
12AX7-R2: (Sovtek 12AX7LPS): Not quite as bright.
7025Y (Ei ECC83): Didn't take notes, but left it in position 3 of my DSL-50.
12AY7: Less bright, very smooth (a lower gain tube than a 12AX7).
I ended up using the following in my 2 amps:
My cheap Epi Galaxie 10 combo: GT 12AX7-M (only one preamp tube, so it made the biggest difference here).
Marshall DSL-50 head:
1 (far left when looking at the back of the amp; input stage): left the stock 12AX7-R2 (LPS); also liked the ECC83-S and 12AX7-M
2 (gain stage): 12AY7 - quieter/less hum/less gain = more usable for non-high gain applications. A big win.
arty07: (12AX7-R2/LPS was stock)
3 (make up gain): left the stock 7025Y (Ei ECC83)
4 (phase inverter): left the stock 12AX7-C
I actually have a couple more lying around that I picked up and never got around to testing - a 12AX7EH (12AX7-R3) and a GT 5751-M (a low gain 12AX7). Have to try again one of these days...
