dNA said:the offset body shape with the tele headstock looks great IMO. good choice.
forgive me if i missed it in a previous post, but is this going to be a one-pup guitar? have you decided on a finish?
rapfohl09 said:dNA said:the offset body shape with the tele headstock looks great IMO. good choice.
Yup, one P-90. This being my first build I elected to keep it simple and straightforward with one pickup and a top loading bridge. My drill press isnt big enough to drill the through holes, and I sure as hell wasnt doing them with a hand drill :laughing7:
As for a finish, I think it will be Lake Placid Blue. If it isn't that, it will be some other fender blue, maybe Ocean Turqoise or Ice Blue.
rapfohl09 said:So I put the bridge on and strung it up for a bit to make sure everything lined up and bolted on right and it sounded great acoustically. I'm pretty pumped. However there was quite a bit of relief. Is that normal for the first time a neck is put under tension? I adjusted it to flat (as close as I could get it anyway, it got hard to turn) then left it for a while. Is that all right? I should say that I adjusted it slowly, in small turns, not just in a big turn.
rapfohl09 said:You know, thinking about it. I probally wont have this all finished and done for like a month or so. Should I take the tension back off the neck? I don't really want to damage it permanently.
rapfohl09 said:Update time! All the machining/woodworking is done! I bit the bullet and went out and bought a Bosch 2.25 HP fixed based router with a table mount and honestly am blown away by how awesome it is. Since I have only been using old routers for my whole woodworking career it was cool to step it up to a new router with soft-start, tons of power, variable speed, great depth control etc. That thing with my Kreg table is just about the greatest combination ever. Anyways, I made the template for the P-90 recess and the cavity cover recess. For the cavity cover I just went and bought a telecaster plate with no holes from GFS. It looks great and is built like a rock. I routed the P-90 recess a little deep so that I can now use springs/washers/foam whatever to actually have some height control. I thought that was a pretty good idea :laughing7:
Pictures to come later, I probally shouldnt upload them at work haha. Right now I'm doing the final wood prep. Filling some divets, sanding like crazy, you know. My paint/clear/sealer will be here tomorrow from ReRanch, and since I dont think I told you what I ordered, ill just leave you guys in suspense :icon_thumright:
