Where did it go? I know there was one with the whole process described step-by-step, but can't find it back except for bits and pieces spread over about 100 topics :-\
Hopefully someone can direct me to it, and if not, I have some specific questions:
So after I finished about 6 or 7 projects with Tru-oil, I wanted to give Tung oil a try. My order should be shipped in a couple of weeks, so I need to get myself prepared!
Now, I remember that not all tung oils are actually pure tung oil, so I need some advise here:
- So, what brand to buy and where?
- which filler and stain goes best with Tung-Oil?
I still have some water based filler left, and usually use either minwax or woodburst. will this work with Tung Oil?
and a special question for Troubled Treble: what color stain did you use on your Korina Strat?
- is there anything I need to do differently when having a body with a different wood as top? this one will be rosewood on Korina.. I guess Rosewood may not need filler, while Korina obviously does.. any good advise on how to approach this?
- when and at which point is it necessary to dilute the Oil, and what's best to use for that?
- what is the main difference in end-result when compared to Tru-Oil? I know that there is some type of synthetic hardener in Tru-oil, but will Tung oil get as hard and glossy as Tru-Oil?
- Can somebody remind me of the exact process? or post a link/copy and paste it from that topic that I can't find back.
Thanks!
Marko
Thanks!
Marko
