Satin step after tru oil?
OneTanMan
I’ve put a number of payers of tru oil on my maple/rosewood neck and the maple parts are completely sealed. Now it’s curing for about two weeks. As a final step I want to knock it back from gloss to satin.
My plan is to rub it with 0000 steel wool with Birchwood Casey gunstock wax as a lubricant, and then wipe the wax off. I plan to do this to the back of the neck as well as the headstock. What do you think about this approach?
You do not need a lubricant, and using the wax that way with steel wool could create a mess. Just use some fine grit abrasive paper, for example 1000 grit just to remove any witness lines etc. Then, if you like to use the gunstock wax, wipe a small amount on and wipe it off. Though, if you want a satin finish, you might be better off using their “Stock Sheen & Conditioner” and following the instructions.
Thanks! I forgot to mention some dust-sized fibers from my cloth got into the last layer in the headstock. I forgot to shake the cloth out after cutting it in half.
I got the idea of sanding with wax lubricant from some furniture videos. I don’t mind a bit of mess since I only use steel wool outside. I worry that sanding without lubricant will cause some problems.
I ordered the stock sheen. Should I apply the gun stock wax after as well?
It would not be needed. As an option that is up to you.
If you have some scrap wood, you could try these things out. Here is a useful thread to read.
I’ve applied the Stock Sheen product. Worked perfectly and left an ultra fast feel on the neck. Thanks for your help!
