Daze of October said:
Okay, I'm confused now. By running IN the effects loop, that will put the effects in BEFORE the preamp, or after? Anything running out the front of the head where the guitar plugs into it would be AFTER the preamp, right? I'm not following the "order" of how everything works. :tard:
How do I hook things into the effects loop? In other words, which jacks do I use on the pedals to plug into the "Send" and which ones do I plug into the "Return?" Could you post a pic of how I connect everything? :help:
OK:
Imagine that you use a custom rack rig that consists of a preamp unit, a separate power amp, and a cabinet. (An example rig might look like
this) These are the connections you would expect each component to have (numbered for use later):
Preamp
1. Guitar IN
[there will be a gain control, and EQ controls on the preamp]
2. Signal OUT - this is the end of the preamp - at this point the signal has been amplified, dirtied up with gain, and EQ'd by the preamp.
Power amp
3. Signal IN - takes a signal ready for amplification
[the power amp probably has no EQ controls, but might have a "master volume" control to control the level of amplification]
4. Signal OUT - now the signal is LOUD but sounds broadly the same as the signal it got in. It's colored slightly but ignore that for our purposes.
Speaker
5. Signal IN - takes a signal powerful enough to move the speaker and create audible sound
Firstly let's do a straight, FX-less rig with this. We plug a guitar into 1. Then we plug a guitar cable from 2 to 3, thus connecting the output of the preamp to the input of the power amp. Finally we connect 4 to 5 with a speaker cable, which can handle the increased power resulting from the power amp. Strum the guitar and wahey, out comes a nice noise.
Now let's say we want to add a Wah pedal. Fine, easy - we plug the guitar into the wah, and then the output of the wah into 1. And off we go, nice wah effect. The wah is BETWEEN the guitar and the preamp.
Now we're going to add reverb. The point of reverb is to give the illusion that the amp is in a large space. We want the reverb to act on the actual sound we've dialled in - the AMP sound, not just the guitar sound. So first, we disconnect 2 from 3. Now we connect 2 to the input of our reverb unit. Finally, we connect the output of the reverb unit to 3. Now the full sound of the amp has reverb applied to it, and is ready to be brought up to full listening level by the power amp. The reverb is BETWEEN the preamp and the power amp.
In a typical head, the preamp and power amp are in the same box. The input on the front of the amp is connection 1. Internally, 2 is already connected to 3. If the amp doesn't have an FX loop then that is just how it works and it stays like that.
If however your amp has an FX loop, then FX Send is connection 2, and FX Return is connection 3. There's probably a clever switch in there so that if there's nothing plugged into these sockets, then 2 and 3 are just connected internally as if the loop wasn't there.
So our strategy would be the same. Wah plugged straight into the guitar and then to the front amp input, and reverb wired in between FX Send and FX return - FX Send wired to reverb INPUT, reverb OUTPUT wired to FX Return. Speakers connected as normal.
Does that make things clearer?
[Modulation FX (chorus, flange, phase) sound different depending on where you put them. EVH had his phaser before the preamp, whereas lush 80s chorus is probably in the FX loop. Some people even have two copies of the same pedal in both locations because of the different sounds achieved]
