Glad you like it. Saddly enough, I'm pretty sure i'm the only one to own a guitar in my neighbourhood.JonatanOTG said::kewlpics:
Nice! I'm pretty sure you're the only one in your neighbourhood with a guitar like that! :icon_thumright:
Thanks for the tip AutoBat. I think you're on the right track on this one. I believe the neck angle/bridge height is involved somehow. It's not just about diapason lenght. It's already 648 mm, with 5 mm of tolerance (i don't know if that's the right word) both ways. So i can't understand why low and high e are intonated, in the same position, while d just doesn't. I put a little veener under the neck and set the bridge as low as possible and it got better, yet not right. I've snatched the idea of the veener from my father's Godin, which has a subtle mahogany one under the neck. That guitar plays like a charm. Get the veener out and it becomes just plain awful.AutoBat said:It's possible the neck wasn't pushed down all the way when the screws were installed. If that's the case it will still be very stable but there will be a small gap on the bridge end screws from the body. (I might've done this before)
:icon_biggrin: Have i ever mentioned you have a lovely sing voice, Cagey? :icon_biggrin:Cagey said:Ahem. Umm... Ok. I was gone for a while, but now I'm back.
I didn't go back over the thread, but is that a Warmoth body/neck? It sounds like your neck is too short for the body. You need to measure from the front of the nut to the center of the bridge. It should be either 24.75" or 25.5" depending on whether you're using a conversion neck or not. If that's a Jaguar neck, it may be a 24" scale part, in which case it won't work on that body without moving the bridge. Or, if you bought the neck or body out of the showcase without noticing that it's a 7/8 scale part, it won't work, either. Can't mix/match those parts like you can with the rest of them.
Finally, when you fret the string at the 12th fret, don't press down hard on it, just touch the fret enough to make the note. If you have large frets, it's surprisingly easy to get your intonation way off because pressing down hard on those frets can seriously sharp the string.
