tfarny said:
Simplest explanation: you're looking at the bottom of the pots.
that is what I am used to... not that I have done that many wirings yet, but this one is driving me crazy!
We wired 2 teles according to this diagram.
the first the way it is.. so as if we are looking at the bottom of the pots, except for the pickups are on the other side ofcourse, and the pins on the 4 way are in a different order than on the pic.
since it didn't really work properly (the bridge was on on all positions) we decided the flip it for the 2nd tele.
this time ended up even worse. Neck worked on most positions, the volume worked in reverse!! and the bridge only worked on the 'inbetween positions.. and by that I mean in between the 1st & 2nd, 2nd and 3th, 3th and 4th!
what the hell happened?
