NoDa75
I haven't pushed the order button yet, just in case someone points out something that I should change (since your order gets delayed a ton when you make changes). Here are the specs for my build:
BODY:
Model: Chambered Flat Top Velocity
Scale: 25-1/2 in
Right/Left: Right Handed
Wood:
Core: Alder
Front Laminate: Roasted Alder
Control Cavity: Rear rout
Pickup Rout: P90-X-P90
Control Rout: 5-Way Switch (Strat) (I will drill the Pot holes myself)
Bridge Type: Hardtail
Bridge Rout: Recessed TOM-Staggered String
Jack Rout: 3/4" Side jack hole
Neck Pocket: Strat Shape
Mounting Holes: 4 bolt
Contours: Forearm contour, tummy cut
Stud install: Will mail in inserts to Warmoth
NECK:
Style: Warmoth
Construction: Modern Tiltback Construction
Scale: 25-1/2 in
Neck Wood:
Shaft Wood: Wenge
Fretboard Wood: Wenge
Nut Width: 1-5/8"
Neck Profile: 59 Roundback
Radius: Straight 12" (because of TOM)
# of Frets: 22
Fret Size: SS6105 (Stainless)
Tuner Ream: 25/64 (Sprezel)
Inlays:
Inlays: No Inlays
Side Dots: White Side Dots
Pre-Cut Installed String Nut: No Nut Install (I will use Zero Glide)
Just want to make sure everything looks right before I order! :toothy10:
BODY:
Scale: 25-1/2 in
Wood:
Core: Alder
NECK:
Style: Warmoth
Scale: 25-1/2 in
Neck Wood:
Shaft Wood: Wenge
Nut Width: 1-5/8"
# of Frets: 22
Inlays:
Inlays: No Inlays
