riverbluff
Well, here it is...
All that is left to do is perform the final set up.
Specs are:
Spalted Maple/Alder body finish by Warmoth in Clear Gloss
Pau Ferro/Pau Ferro neck 1 11/16 standard Thin Contour 6105 SS frets
Planet Waves locking tuners
250K pots and .22. cap
BareKnuckle Piledrive pickups in Bridge and Neck.
It sound great. Very tight driving sound with the gain on the amp cranked up and the volume on the guitar at full, but really has that tele sound when you roll off the volume a bit. Super clean on the clean channel.
Very happy with the neck so far. It feels fantastic and it appears to be about perfect with just the bacis set up. Once the strings went on, it pulled to the correct relief, and there appears to be no dead spots on any of the frets. The Warmoth installed nut is about as perfect as you can get. As long as it all stays that way through the rest of the set up.
V/R
Bill
Specs are:
V/R
Bill
