Had a busy week-end learning how to plane a very rough piece of wood with just a router because feeding curly maple to a planer didn't work so well (got to learn the hard way)...
From there I built a tremolo cover, and another set of truss-rod+control plate.
Everything went fine except at the last stage when routing the control back plate from the wrong side.
2nd pic: that moment when you realize you just made a left-handed cover...
I salvaged it by routing out the bump and gluing another piece of wood on the other side, maybe that's better that way for rigidity anyways.
It removed a little bit too much material though, the cover is slightly thinner than the plastic one Warmoth includes.
The truss rod cover was a bit of an experiment, done entirely with a dremel cutting wheel...
It was much faster to do than it sounds.
A single piece was way too flexible, but laminating and gluing two thiner pieces made it incredibly rigid. Wonder how the stain will react at the glue joint though.
I'll build another set of control backplate and tremolo cover tonight, there's a piece of wood that seems to have even more iridescence and could look even better on this build.
Also got the Gotoh 510 yesterday and installed the stained wood buttons on it (last pic)!
