fretless
http://www.shellac.net/ShellacPricing.html
http://www.minwax.com/wood-products/interior-clear-protective-finishes/minwax-wipeon-poly
Use dewaxed if you plan to shoot nitro or any other finish over it . I always use the dewaxed flake for ease of use when making it. It's super simple just brush it on dries in 20 min , flip it over and brush the other side . I use mason jars from the hardware store and leave it in the kitchen to dissolve , it can take almost a week to dissolve so start ahead of the build , then strain it with a paint filter into a clean jar.Do a few wash coats and move on to your preferred finish . You could just keep on using Shellac , like a fine acoustic or violin maker would . Use a Platina for almost water clear no color or mix any of the shades together for your preference . Shellac dries very quickly and does't seep in and saturate the wood like a oil finish can , some say this is better for tone .You can tru-oil over it but I've come to love Minwax wipe-on poly . It dries in a couple hours , can be sanded or simply steelwool'd and leaves a stunning natural and protective finish that really brings out the natural beauty of the wood . It doesn't stink as much though both Shellac and MWWO should be done with excellent ventilation Shellac uses 190 Proof - Denatured Alcohol and the vapor will get you so high you should not drive. http://www.shellac.net/alcohol.html
It's also cheap and one can would do many many instruments . I've come to prefer it over tru-oil as well , especially the satin for both bodies and necks . A instrument can be finished in one day with final buffing or sanding the next day and waxed for a stunning glow . Simple cheap , easy . So if you like a natural finish , like a Seagull guitar or some nice satin finishes you see try it . I have also used only Minwax and it worked perfectly and only Shellac and that is fine as well but I like the grain enhancing and protection of both the most . :glasses9:
Some instruments I've finished
Precision kit ,Shellac Platina wash coat , Minwax wipeon satin finish
Renegade body Warmoth neck tele , Shellac Blonde with Minwax wipeon
Renegade body / Warmoth LP neck ,Shellac Blonde & Garnet mix , MWWO
Warmoth Snakehead , Shellac Super blonde w/ MWWO
Warmoth 32" SC w/ Padouk neck .Shellac Super Blonde and wax only
The orange color actually dies the Shellac and so I had to use a different jar of it for the body :icon_biggrin:
Warmoth 32" J finished by Joe \m/
Joe used Minwax wipeon Glossy on this onepiece Walnut & Ziricote neck
'51 Poplar P , Shellac super blonde w/ Minwax wipeon
