TBurst Std said:
Myself, I have a Peterson strobo stomp for my serious work. For intonating:
I start with open and 12 and set it.
I then check harmonics at 5 and 17 noting how many cents they are off
The I set it using 5 and 17. Then check it open and 12 and note how many cents off.
I split the difference and set it there.
Basically I set it so it’s as far off from open/ 12 as it is 5/17. Your normally talking 2-3 cents.
Sounds like a good method, but, there is no harmonic at 17th that's worth mentioning.
There's one on the 16th that's a major 3rd from the root one that's on the 5th ...
Even so, if you are using harmonics they're a division of the open string so I'm gonna guess you mean ?
Do you mean to say you check the fretted noted at 5th and 17th?
Thanks!
