Do you think you could set the neck with a warmoth LP body and neck, if Warmoth didnt cut the pocket in the body for the bolt on neck to go in, and if you shaved the under side of the neck to how gibson cuts it, and also cutting your own groove on the body to set the neck?
Or would it throw everything off or do you need the Tenon to be longer.
