Audiowonderland
I am using Duplicolor Perfect Match. I need to lay down a black base for the pearl paint that will be the finish color. Its a lacquer and each coat should melt into the previous. With that in mind, is there any advantage in leveling the black base coats back before putting the pearl coats on top since I will need to level the clear coats regardless?
