kdas3
Hi everyone,
So...I stupidly bought a set of tele pickups from bareknuckle with stock polarity (both neck and bridge have the same polarity, not sure which as I haven't checked!). The neck came with 3 wires for a series mod, meaning the ground wire for the cover is separated. Seeing as I live in Melbourne Australia, sending the pickups back and buying a new set would probably amount to like 80AUD in shipping total. But...I think it is possible to fix this. I believe I can simulate a RWRP neck pickup by
[list type=decimal]
[*] Reversing the neck pickup polarity by passing it through a strong magnetic field generated by neodymiun magnets. I'll probably get my tech to do this, and yes this will probably kill the warranty. This will legitimately give me RP.
[*]Swapping the hot and ground wires on the neck pickup. No issues with the ground cover wire as it's already separated. This will simulate RW.
[/list]
Now with single coil pickups (at least with Strat and Tele I believe), there is often an issue with swapping the hot and ground wires, as the initial coil winds touch the magnets. I'm getting this info from the section 'Reversing the Leads' in
https://www.fralinpickups.com/2020/04/10/how-to-reverse-pickup-phase/
I believe the issue here is that, if you swap the leads on a strat or tele pickup, touching the pole pieces will create a loud hum or something to that effect. But, my tele neck pickup has a cover, so is that even a problem?
Also, I'm not entirely sure how remagnetising pickups works. Can you magnetise it to varying strengths? If so, when remagnetised, could the pickup sound different?
Lastly, Bareknuckle claim that a RWRP set of tele pickups sound worse when in series as opposed to a stock pair. Do we agree/disagree, and any idea why this would be the case (scientifically)?
[list type=decimal]
[/list]
