Broke in my new Hipshot Ibby high mass hardtail; much much nicer than when I recieved it, Rounded the sharp corners and sharp edges so resting my hand against the bridge is as comfortable as an old pair of sneakers..... now playing my guitar will be fun and enjoyable.
I have found that when I go through a guitar piece by piece and smooth and soften as many rough areas as possible, it changes the guitar from being a really good guitar to being a really great guitar, of course I have the time to work on just one part at a time as I get them, I know some guys are building for a living and it may not be productive time wise, but you'll never convince me of that, once you've picked up a guitar that feels smooth as butter in everyway you'll find yourself going back to it over and over, which to me would be the whole point (or should I say "NON-Point-y", yeah I just said that ...) of building guitars for other people to buy; as a reflection of superior craftsmanship.
I smoothed the string thru holes to prevent string breakage where the strings pass thru the bridge, as well as, the two mounting holes in preperation of the 8/32" Stainless Steel machine screws and inserts I'm going to sink into the body for mounting purposes, the inserts and machine screws hadn't arrived yet so I used Neck screws in the pics to show compatibility.
I know wearing the parts isn't everyones cup of tea, but it makes every guitar I build special to me, I try to spend as much time and intimate attention to detail in every area and at every stage of the build that I can, so that in the end the guitar truly is an old friend.
The tools for the job:
Flat files, needle files and sanding sponges.
Making sure the 8/32" machine screws for the threaded inserts Im using to mount the bridge to the body will slide through the mounting holes, I used Neck screws for reference until the machine screws and inserts arrive. just a note: it didnt take much to get these to fit, just smoothing the holes was enough.
Very sharp edges where the strings pass through the bridge plate, yikes! that can't be good.
Rounding all the string through holes so the strings don't get cut or break on the sharp edges on their way from the ferrules to the saddles.
you can see how rounded and smooth the pass through holes are now. Yay!
Very sharp edges and pointy corners all along the top where the adjustment screws pass thru the back of the bridge... flesh shredding, not on my watch...
Very pointy and sharp corners at the sides where the hand slides back and forth... ouch!. Not gonna happen.
The sharp base plate edges already scratched my guitar once just laying it on for reference, not gonna happen again.
This bridge may no longer be Black, but it is a premium functioning piece of hardware maximized for performance now.
