Jumble Jumble
So I've had a good look and I can't really find a thread that's solely about this subject. It quite often comes up in other threads, but it's often not really appropriate to the actual subject of the thread. So in this thread we can actually devote ourselves to talking about analog vs digital amps. Where we've got to, where we've been, the pros and cons, and so on.
Let's keep it to amps and save FX for another day.
So, I'll start with a summary of my opinions and experience with these.
Analog amps: I've said "analog" rather than tube because of course, transistor amps have existed for a long time. So we have our favourite amps like Marshall's JCM800 in the tube corner, along with stuff like Roland's JC-120 in the transistor camp.
Digital amps: this is everything from an iPhone app like AmpliTube, through mid-range stuff like the POD, up to the frighteningly powerful and expensive Axe FX.
A key thing that I immediately found when I first started playing around with modelling (a Pod 2 a decade ago) is that they don't sound like a real amp. Wait, what? Isn't that a bit of a problem? Yes, maybe it is. When I play a real amp (say a Marshall half-stack), the sound is instantly identifiable. A 4x12 just sounds like a 4x12 and nothing else sounds like it. As you move your head around the room, the sound changes because those speakers are so focused. And there's a lot of air moving - you can really feel it.
However, and this is the key realisation that it took me quite a long time to get to: that is not the sound you're hearing on your favourite albums, and it's not the sound you're hearing at big gigs (anything where the guitar amp itself isn't providing the bulk of the sound to the audience). The cabinet has one or more mics pointed at it, and that is the tone on the record or coming over the PA. That recorded sound is what modellers are aimed at achieving. What this means is that even if they sound good, they don't feel right. I really noticed that I didn't feel like what I was playing sounded as good as it did on my real amp, but when I played back a recording of my playing it sounded more or less how I would expect it to sound. The modeller was doing its job quite well.
The other thing, of course, was that the POD 2 really wasn't that great of a modeller. It didn't have many amp models and the ones it did have weren't particularly great-sounding. This led to me abandoning the POD and going back to tube amps.
Now of course modelling has massively improved. It has got to the point where a recorded sound from a modeller is indistinguishable from a recorded sound from a real amp. It still doesn't give you the "amp in the room" feeling, but to a listener it gives the "amp in front of the mic" feeling perfectly.
The other thing is, you can now turn off cab simulation in the modellers and run the output into a real guitar cab. I haven't actually tried this yet, but in theory that's the path to go down to get the "amp in the room" feeling back. You could sit down in front of your 4x12 and play your stuff, feeling the power and focus of the cabinet, while you take a direct output from the modeller to the recording desk so that you don't need to bother with microphones. I can imagine that being a popular option, if it works.
Here are some different playing situations and the pros and cons.
Home practice (no limit on noise level)
Surely a real amp wins here outright. If you can crank it without getting into trouble, then it's just too much fun to do anything else. A modeller through some big speakers will be fun, but it won't be the same.
Home practice (with a noise limit)
There are two ways around this. One is to get a really small tube amp, like 5W or even 1W. This supposedly allows you to crank the output up, driving the amp, without it getting too loud. I don't know about you, but this doesn't work for me. I still have to turn the amp down really really quiet if I don't want the neighbours to hear. You might be able to plug headphones into your little tube amp, but then the cab is having no effect on the sound so you're not getting the full experience.
The other option is of course to use a modeller - you can run it at any volume you like without affecting sound, or you can plug in a set of headphones. This will basically sound like you're sitting playing in the control room in a studio with your amp next door, mic'd up. This is a great way of doing silent practice.
Recording
Real: Of course you can set up your real amp, get the exact tone you want, then mic it up. A good engineer should be able to get the tone of your amp as you hear it from your favourite part of the room, on to tape. The only downsides of this are: you need a good engineer; it takes time to set up; you need to rent studio space for the whole time you're recording.
Digital: If you have a good modeller then this works just as well as a real amp. With the Kemper (and I think the Axe FX II), you could even set your own amp up in a studio, profile it, and then have that sound whenever you need it. This means you can do the rest of your recording at home without the need for studio rental. Of course, the usual modelling thing also applies: you can have a LOT of amps, some of which would be very very expensive to rent or buy.
Small gigs
What I mean here is a gig where your amp is providing the sound that the audience hears - no PA system and no mic on the amp. What to use:
Real amp - pros: You get the feeling and fun of playing in front of a real cab.
Real amp - cons: What you hear and what the audience hear might be different, depending on where a listener is in the room.
Digital amp - pros: You hear what the audience hears; more amps available.
Digital amp - cons: Might be difficult to get feedback; no feeling from the cab.
Big gigs
Very similar pros and cons
Real amp - cons: What you hear and what the audience hear will be different, as the audience hear the mic output.
There are also pros and cons that apply to all scenarios. The digital amps are much lighter and more portable than tube amps. With digital if there's a PA at the gig you don't need to take a cabinet. Digital gives you more amps on hand. Digital does not have tubes to fail and be replaced. Digital power amps don't blow up without a speaker plugged in. Digital amps are based around computers; in theory at least, computers sometimes crash.
I'm interested to here more pros and cons in different scenarios, or especially if you own both, which ones you use in which scenarios and why.
I'm not very interested in unsupported opinion statements like "modelling is better, period" or "digital stuff has no soul". They don't add anything to the conversation and don't help anyone who might be researching the topic.
I plan to back up what I've said about being able to tell the difference quite soon, by posting up a whole bunch of clips recorded in both ways. Once we have a lot of attempts at correctly identifying them we can look at some averages and see how we do.
Recording
Small gigs
Big gigs
