I wish mine had them, but both of mine are hollow... :dontknow:DMRACO said:I love the tummy cut on teles. I have it on mine. Fender should make it standard.
Cagey said:Purple does seem to be getting more popular. Might be because so few examples exist.
As for your little lovely, we're doing fine. Should ship Monday or Tuesday, depending on transportation issues. Shouldn't have taken this long, but the weather here has been atrocious, so the garage is beyond miserable. On the plus side, your neck has seen some pretty wild temperature and humidity changes and it hasn't moved. That Warmoth Pro design is the whip. I'll try to post some pictures later.
Bagman67 said:
pabloman said:I held on to those things for a long time hoping to find the right home for them. Looks like that finally happened.ccasion14:
Bagman67 said:You definitely nailed the placement of the volume and tone knobs, Cagey. Perfect.
reluctant-builder said:Absolutely amazing.
Cagey said:Bagman67 said:You definitely nailed the placement of the volume and tone knobs, Cagey. Perfect.
Thanks. You'll also notice that the pickup selector switch isn't exactly up/down or forward/back, it's in a sweep line with the volume/tone controls. But, it's a beefy enough switch that you can slap it up/forward or back/down and still get the results you need. Shouldn't get in your way regardless of what you're used to, but once you get used to this, you'll wonder why anyone does it different.
