Cagey
Mythical Status
You guys. Why do you want to experiment with $500 necks? DO IT RIGHT!
Don't rethread a threaded hole with a different threaded insert. If it's an insert that wants a 5/16-16 thread, then that's the tap you need. They're not easy to find, but they're certainly out there and I've given links to suppliers. If you forcefully rethread it, you're just going to chew up the wood and wreck whatever thread you have, which defeats the purpose of the whole exercise. You're trying to get a tight bond between the neck and the body.
Don't epoxy the things in. You may need to get them out some day, and you'll have a bitch-kitty of a time doing that if they're cemented in. The likelihood of your needing to do that is small, unless you cross-thread the insert going in, or cross-thread the bolt when you install the neck. But, both of those things are easily possible if things don't end up square.
If your insert, hole and tap are matched, the thing will be in there plenty tight, it's likely to go in square, and all will be right with the world.
