Cobretti86
I ordered a warmoth pro neck and a fender strat style warmoth body with a contoured heel (awesome.. im in love and am waiting to assemble), not the offset one which places the screw in a different position, just shaved down and able to accept the the standard neck plate and it uses two shorter screws in the top two holes of the neck. Now, i read online that the warmoth pro neck is not compatible with the contoured heel, the offset one, because the screw placement interferes with the dbl truss rod. So is it safe to assume that my warmoth pro neck will work fine with my contoured heel using the 2 longer/2shorter screw lengths provided? The screw holes are still in their normal, or standard, positions. All I can find on the website is info saying that it doesn't work with the offset contoured heel. I will not sleep until I get an answer on this. Please help!!! Thanks.
