nope ordered the tele set the base on the neck pick up wouldn't fit in the opening about an 1/8" to big
The screw holes in the bridge pick up base didn't line up with trhe holes in the bridge. had to dill them out in order to get the pick up to work. used the dremal with a sanding spool to take enough out of the neck spot so it would mount. on my 1st build I use fender custom shop nocasters and everthing was a perfict match. go figure? all very fixable things just surprized they weren't closer fender spec. any way i needed an excuse to go buy a derma
l
