line6man said:JCizzle said:line6man said:There is also the option of a Gibson style midrange cut control. Would that be useful on a Strat?
Is that like a specific EQ knob? This build isn't a traditional "strat," per se...
If you put a capacitor in series with an inductor, in series with a variable resistor, and then put all that parallel to the signal, you get a sort of bandstop that lowers impedance for the midrange frequencies. The capacitor blocks out the low frequencies, while the inductor blocks out the high frequencies, so what's left in the middle is diverted to ground. The limits of the bandwidth can be tweaked by changing the value of the capacitor and inductor.
Again, I don't know that such things are truly useful in practical applications, but it's worth trying, as something to fill the third hole and keep up appearances.
Dan0 said:line6man said:JCizzle said:line6man said:There is also the option of a Gibson style midrange cut control. Would that be useful on a Strat?
i did some playing with variations on it. basically the "varitone" approach didin't work for me because it's too hard for me to hear the differences in cut frequency it's just useless options for me, i found just one setting with a pot did the trick, also i had the cut frequency pretty high and it more or less sounded like a traditional tone but not muddy, more pleasant since it keeps the upper treble, so it didn't really compliment the traditional tone but was an alternative to it so i took out the tone and wired the notch filter sorta like the traditional strat setup with two knobs operating different pickups. the bass cut like on a g&l is probably more useful.
keep in mind that i have some hearing loss mostly up around 5khz so the tone circuit stuff might not be the best for me to judge.
there is also the Schottky diode "overdrive" knob. but i think that would work better as a switch, stewmac has a product that is essentially this called the "black ice" or something.
or what about two volumes like a gibson? with a super switch you could work this out using 3 pickups where the first volume is always in use and the second is only used if 2 pups are being used at once. if you did this and used a stacked pot for the tone so you can have similar to the full gibson set of controls.
Dan0 said:there is also the Schottky diode "overdrive" knob. but i think that would work better as a switch, stewmac has a product that is essentially this called the "black ice" or something.
JCizzle said:Dan0 said:line6man said:JCizzle said:line6man said:There is also the option of a Gibson style midrange cut control. Would that be useful on a Strat?
Now this has my attention. I wasn't sure if that was even possible. How would I go about wiring something like that? I wonder what would be better, a volume just for the bridge and one for the middle and neck, or the other way around...
