Relating to my buildout of this bad boy: http://unofficialwarmoth.com/index.php?topic=23303.0
I'm still slightly up in the air on the wiring scheme.
As far as the 5way switch, I'm planning on doing classic B/B+M/M/M+N/N wiring
I'm basically sold on a Volume/PTB scheme for my pots, but I have a push/pull available, and I'm waffling as to whether to do:
http://www.seymourduncan.com/tonefiend/guitar/two-band-ptb-tone-control-useful-easy-cheap-awesome/
A) Activate bridge pickup to get B+N and B+M+N options
B) Blower switch - Bridge (or Neck - since it's a Bari) direct to output jack
C) True Coil tap, running tap directly to ground
D) Faux coil tap, running the tap through a capacitor to ground
E) Series/Parallel/Phase
All of which I have used at one point or another in one of my other guitars
I have a Megaswitch at hand if there are other super-duper options that I'm not thinking of that could use a DPDT and the options available there... and I'm not averse to placing an order for more Push/Pull pots if there's a killer mod I'm missing.
Barring anything compelling, I'm planning on option A.
