DustyCat
The first is something I saw in Musician's Friend like 10 years ago, but now that I have a strat with a floyd rose, I can't find it anywhere (it doesn't help that I don't know the name of the item) but it's a screw or a sleeve that (if I remember correctly) keeps the floating bridge in place so that you can still use it as normal (divebombs and whinnies) and still bend the strings without the floating bridge moving so the strings get loose and go flat (pedal steel licks/country bending to a stationary upper string are just about impossible, cause the one string will always be flat.
Any rememedies???
The other is a strap that looks like an "X" and distributes the weight of the guitar evenly across both shoulders to help eliminate back problems from uneven weight distribution.
Any rememedies???
