Neck Plate required? Or can I use...
GuitarEC
I've been doing a lot of snooping around on the web and happened to run across this on Stewart-MacDonald's website:
http://www.stewmac.com/shop/Hardware,_parts/Electric_guitar:_Covers_plates/Neck_Mounting_Ferrules.html
Can these Neck Mounting Ferrules be used in lieu of a traditional neck plate on Warmoth bodies / necks?  Has anyone used these?
Many thanks,
Eric "GuitarEC"
ibob74
I haven't tried with a Warmoth, build but I do own a couple of guitars with the neck ferrule technique, seems to be as solid as a neck plate. You would have to do the counter bores yourself as Warmoth does not do this, that I know of.
Jwheeler
They also have those ferrules at W, and they say that with their holes drilled where they are, they are a little too close to the edge.  You may have to have the neck and pocket undrilled an drill it your self.  I have an Ibanez RG that has those and it is a pretty cool look.
rahimiiii
Can't you just use a 5/16 bit to enlarge the hole until the required depth? I mean it seriously can't be that hard to counterbore a hole!
bpmorton777
the danger is that the ferrule holes will spill over the side of the neck heal, weakening the joint and ruining the body and neck. before sawing out my body i bought a neck plate to make sure my mesurements were right and that it wouldnt hang over the edge..sorrta the same thing
Brian
jackthehack
I think I read on a thread - maybe on the old board - that you could special order a body without the neck holes drilled, but don't remember if that made for any warranty issues or an upcharge....
bpmorton777
there is a $15 upcharge for no holes in the neck, i imagine that it's another $15 for no holes in the body as well.
Brian
