Neck Leveling
ChrisK
When I'm re-leveling my fretboard prior to re-fretting, how should I have the truss rod. Relaxed ?? or under some tension. The humidity here is like 25%. Any expert help would be appreciated.
Chris
Under enough tension to have the board as straight as itll get.  Just make sure to keep checking it after each fret you seat.  They have their own compression effect depending on the width of the tang.
you also need to properly support the back of the neck so it doesn't bow under your levelling pressure, creating a bow in the center. the neck should be supported when levelling the fretboard/fingerboard and when levelling the frets
all the best,
R
Patrick - long post??? I don't see anything besides your three short sentences. maybe the c/p failed to get included?
R
R
First sentence of last post is a link....
