MattPurland
Here's the body, bridge pickup and trem. Mahogany core, Zebrawood top, Seymour Duncan TB-14, black FR. Still waiting on the neck (apologies to the people who replied to my panic thread in the general forum)
MattPurland said:You think everything's awesome![]()
Yeah, angled pocket - I'm a huge EVH fan and I've had floating floyds before, I guess I prefer the stability when bending/breaking strings.dmraco said:can't wait...WARMOTH must have had a run on zebra wood....Lots of them floating aorudn the board these days...
I notice you did not recess the floyd. I assume you angled the neck pocket. I went the other way...I am curious to see how it turns out...
are you going to stain the neck too? If you are..the zebra wood takes the stain much better (read darker) than the maple...
You should be able to rest it flat against the body, just depends on how everything fits together, personally I like mine just a little off of the body. Mainly to keep from damaging the body, and you can always block the trem from the underside so it won't pull up...MattPurland said:I really like yours, looks more like tiger skin than zebra!
Edit: one thing that's just scarily dawned on me, with the floyd w/angled pocket, does that mean I can have the trem flat against the body, ala EVH? Or does it mean it floats above the body? I've actually had a strat with a floyd that floated above the body, and I didn't like it... the neck pocket was way more angled though
MattPurland said:Good, I've thought of putting something between the trem and the body, maybe a thin piece of plastic. Eddie used a coin - f*ck that!
Most of mine that I don't want any pull up action, I take a small piece of material, such as aluminum or phenolic. And bolt it down in the underside cavity rout, so that the trem block rests up against it.MattPurland said:Good, I've thought of putting something between the trem and the body, maybe a thin piece of plastic. Eddie used a coin - f*ck that!
DangerousR6 said:Most of mine that I don't want any pull up action, I take a small piece of material, such as aluminum or phenolic. And bolt it down in the underside cavity rout, so that the trem block rests up against it.MattPurland said:Good, I've thought of putting something between the trem and the body, maybe a thin piece of plastic. Eddie used a coin - f*ck that!
I normally use the same string gauge all the time, but I don't see that it would make much of a difference...But it could be made to be adjustable...dmraco said:DangerousR6 said:Most of mine that I don't want any pull up action, I take a small piece of material, such as aluminum or phenolic. And bolt it down in the underside cavity rout, so that the trem block rests up against it.MattPurland said:Good, I've thought of putting something between the trem and the body, maybe a thin piece of plastic. Eddie used a coin - f*ck that!
very nice idea..I bet it helps when a string breaks too!
Do you have to adjust it with different gauges of strings??
