stankybudz
I recently obtained an 89 gibson sg jr I believe, as it only has the one humbucker rout. When i got it, it had like a super thick hideous green high tensile paint with a cross painted over it, so I had it sanded down and finished with a non polyurethane cherry stain. I got it for 80 bucks, and it felt and played like a gibson so I felt it was a steal. I switched the pickup to an old duncan performer and had a few issues fitting the new pup to the old mounting ring and pickup height, so I did a direct mount and used plastic inserts to compensate for the amount of space between the strings and pup that I would have had if I screwed it directly into the wood. I didnt realize the wood was so thin there and actually drilled through the back of the body, so I smacked the inserts down about 3/4 of the way and screwed the pup into the inserts, and the actual height between the strings and pup is not too low. I got everything wired up and sounding pretty good, but am now having the issue with some fret buzz. This axe came with this funky steinberger fixed floating rollers bridge, and I've sorta been able to adjust it a little bit, but I'm super new to guitar repair and set up and I really want to learn how to do it. I would like to know if with the way the bridge rout is , do i have any options with dropping a tremolo in? I am not opposed to routing the back out for the springs either, so let me know my options please and thanks!
