lafromla1
My first build was a VIP that I absolutely love, but I also wanted to make a strat-style body.
Starting with this:
I taped off the fretboard (for later oiling) and began the process of oiling the neck with Pure Tung oil. The first coat was a mix of 4/5 citrus solvent and 1/5 oil. I coated the neck, left it on for about 10 minutes and then wiped the excess off. Then I let it dry for 48 hours. I hung it on a clothes rack with a wire hanger placed through the top tuner hole and put a small desk fan on low while it dried. Every few hours I would wipe off (in) any excess oil that may have seeped up. I did the same for the second coat, but I used a 50-50 mixture.
On the third coat I used only oil and you can definitely tell the difference when applying it as compared to thinning it down. It went on very thick. I left it on for about 5 minutes and then wiped it off (in) with some vigor as to get the oil into any open pores that may still be there. I'll continue to wipe off any excess that seeps.
I'll let it sit for approximately 72 hours as I am waiting for the Butcher's White Diamond wax I ordered to arrive.
Sorry for the quality of the pics. I'll get better ones as I keep going. The color on the neck is exactly what I wanted (thanks Max and CB :icon_thumright
. The grain looks incredible as the oil brought it out perfectly.
More pics as I continue the journey.
Starting with this:
