GoDrex said:Is there another?
Nope, Iron maiden was a torture device in the middle ages. Reminds me of the excellent adventures of Bill and TedRyan (Rounce55) said:GoDrex said:Is there another?
I don't know, there could be like a steel maiden. :icon_scratch:
Ouch?Wana's_makin'_a_guitar said:Nope, Iron maiden was a torture device in the middle ages. Reminds me of the excellent adventures of Bill and TedRyan (Rounce55) said:GoDrex said:Is there another?
GoDrex said:
Wana's_makin'_a_guitar said:Wait up, I just saw that your American power point plugs are different to us in Aus
And I wanted to have and amp shipped over some time next year.
ByteFrenzy said:The plug/cord will be the least of your worries. If the cord isn't permanently attached it will plug into the amp with the same plug you'll also find on the power cord of your computer or your screen, so you could just use another cable. Worse is that I think Australia has 220V 50Hz and the US have 120V 60Hz. The frequency won't be a problem (that's just for motors that need to run at more or less the correct speed), but the voltage difference would not be healthy for an amp. You could get a step-down transformer but they are usually heavy, expensive and hard to find. The adjustable ones also have the risk that they could accidentaly be jarred and cause your amp to blow up. Maybe you should consider getting your amp from Europe - I dont know what the rate of the UK pound vs the AU dollar is up to, but that could be a deal as well.
Sure does. And Byte, you were soooo close. I just looked on the back of my MG 30 and it says the mains input is 230v-50Hz.DocNrock said:ByteFrenzy said:The plug/cord will be the least of your worries. If the cord isn't permanently attached it will plug into the amp with the same plug you'll also find on the power cord of your computer or your screen, so you could just use another cable. Worse is that I think Australia has 220V 50Hz and the US have 120V 60Hz. The frequency won't be a problem (that's just for motors that need to run at more or less the correct speed), but the voltage difference would not be healthy for an amp. You could get a step-down transformer but they are usually heavy, expensive and hard to find. The adjustable ones also have the risk that they could accidentaly be jarred and cause your amp to blow up. Maybe you should consider getting your amp from Europe - I dont know what the rate of the UK pound vs the AU dollar is up to, but that could be a deal as well.
Sounds like a man who knows far more about this than me. :icon_thumright:
DocNrock said:Sounds like a man who knows far more about this than me. :icon_thumright:
Wana's_makin'_a_guitar said:And Byte, you were soooo close. I just looked on the back of my MG 30 and it says the mains input is 230v-50Hz.
metalman22105 said:NIIIIIICE!!! :headbang:
GoDrex said:
:headbang1:DocNrock said:GoDrex said:
Just got back from DC and had visited the International Museum of Crime and Punishment. They had a display dedicated to the Iron Maiden. Apparently, in addition to the blades on the inside, it was also air tight. Not only would one bleed to death once the chamber was closed, but this was also compounded by suffocation.
