I hadn't until now! Hmmm...docteurseb said:Looking forward to this one, what a cool idea.
Are you considering doing a matching backplate cover made out of purple wood ?
For sure, all AC/DC... :headbanging:Cagey said:Great soundtrack on that flick.
:headbang:Cagey said:Otherwise, not too sure. First time I ever heard of a "worst director" or "worst actor" award, but Stephen King and Emilio Estevez managed to snag those. I actually thought it was kinda fun, but then I like old Lost in Space reruns, too, so... Some discussion of all that here, if anyone's interested.
VinceClortho said:In order to block the Floyd I installed set screws in the trem block.
Mayfly said:VinceClortho said:In order to block the Floyd I installed set screws in the trem block.
Now THAT is a hell of an Idea!
VinceClortho said:Pickups mounted and knobs in place.
Trem in place and blocked with control cavity cover mounted. It is starting to get close to looking finished!
DMRACO said:This is shaping up to be a really nice axe. I cannot wait to see the two married together.
What is going on with the electronics? Is that a micro USB I see on the cover?
stratamania said:DMRACO said:This is shaping up to be a really nice axe. I cannot wait to see the two married together.
Its probably a Fishman charger for the pickups.
Thanks for the kind words on the build! It'll be together soon.DMRACO said:stratamania said:DMRACO said:This is shaping up to be a really nice axe. I cannot wait to see the two married together.
That's cool. I have installed a Fishman Power Bridge before. I never knew that had rechargeable model pickups/pre-amp
Thanks. I have tried most of the usual blocking methods for Floyds over the years and this way is my current preferred way to block to dive only. It is easy to do, requires no drilling to the guitar body, and can be adjusted or disengaged in situ with a stubby hex wrench. It does work fine with one set screw centered in the block but I just feel better having two for no particular reason.Mayfly said:VinceClortho said:In order to block the Floyd I installed set screws in the trem block.
Thank you. :headbang: In my real job I have to do a bit of small scale machining, not much but enough to give me the tools and confidence to try making some simple parts and modifications.PhilHill said:Excellent work there. You strike me as someone who evidently has some level of machining and fabrication experience in your past. Your quality of work and finish is first rate. Salute! :icon_thumright:
