Tonar8352
I started this mahogany Strat for nullref and I'll be doing a cherry red. The first step is to fill it with cherry paste filler. I had to mix this using a neutral paste filler and powdered aniline dye from LMI. The trick with this is to use a mortar and pestle to grind the color into your paste filler. Here it is with just the paste filler. The next step will be to make a dye with shellac solvent and more of the powder so the color will be much more intense. I'll do that later this week once the filler sets up real good.
