Link on easy way to shim a Floyd to match a Warmoth radius
I know this is an old topic, but I can't seem to find 0.2mm shims. The only ones available in the US are 0.15mm.. Can anyone help?
The difference between 0,2 and 0,15 mm is about the same as the thickness of a human hair.
Instead of raising one saddle that infitesmal amount, perhaps you could lower the one next to it by filing down the string slot that same miniscule amount. That would make the saddles line up to a flatter radius.  :dontknow:
See your other thread I have provided a link in that one.
It might be a good idea to get some of each size depending on how close you want to adjust things.
