It's a slow start, but it's started. Co-worker broke her arm so now I get maybe 1 to 2 weekends a month off until she's back.
What I've done so far: Sanded 220, raised the grain and sanded 3 times, masked off for natural binding and put down a very thinned coat of shellac, broke all sharp corners with 220, and drilled for toggle switch. Have run into one issue, when removing the tape for the natual binding, two "splinters" were pulled out. Didn't notice until I was applying the shellac. So I'll have to add some grain filler in that spot. Anyone know if applying clear grain filler over shellac will blend in color wise? If not I may just wait and drop fill some lacquer to build it back up.
Anyways the pics I have show the masking that was done and the final look for the natural binding. Most of the time the natural binding is done with the edge of the flame maple exposed, but I wanted something different and thought it would look better if the top of the Alder were exposed instead. Next step will be staining the top when the weather clears up. Which according to the weather channel, will be 2 weeks. :hello2:
Will post more as I go along. :headbang1:
