My daughter and I agreed on the Suhr series/parallel auto split option. It looks like a super versatile setup and combines some of my favorite tones. I'm very excited to hear the parallel neck and bridge tones. I have a Seymour Duncan Jazz in the neck of another guitar and love the series/parallel. Also, Pete Thorn has his bridge pickup wired series/parallel so since I'm using his pickups I figured it would be a safe bet.
Moving very slow I was able to follow the diagram. I had to stop a few times, replace wires, fix solder joints, but overall it went pretty smooth. For some reason soldering was hit and miss. I used flux, tinned everything the best I could, and sometimes I'd get great looking joints. However, other times the solder would ball up, roll around, and not stick to anything. I haven't researched it yet, but if anyone has soldering tips I'm all ears.
I wasn't sure which order to go in so I started by wiring all the jumpers and leads on the switch. I then transitioned to the tone pot starting with ground and just worked my way around the switch. I finished with the volume and output jack. I'm sure there's a better way to navigate the wiring as mine resulted in a bit of a rats nest.
Here are a few pics:
Started here thinking I was a soldering master:
Multiple hours later, and fully humbled, this is my end result:
It looks a bit better on the control plate, but it's still a mess of wires...and I still need to wire in the pickups:
One quick note. Do NOT play $5+ for a treble bleed, and do NOT pay someone $15-20 bucks to install one as a "custom" option. $.07 and 3 minutes is all it takes to make one AND wire it in. If I can do it anyone can.
Tomorrow I'm going to test all my grounds, wire the pickups, and hopefully be jamming with my kid by late afternoon. But...I have a feeling there will be some gremlins in the wiring so wish me luck!
