Korina/Koa L5S Thank you Santa!
willyk
Literally out of the box this morning. Black korina back and a great looking koa top. I tried the hardware on for size as well as the neck. (note the regular switchcraft toggle switches are too long. So if you're building a flat top hollow body use a box type or a sideways switchcraft) This is my first body with binding so here goes nuthin' See y'all in DIY  (  probably under... :help: )  :icon_biggrin:
R
RLW
Wow, that's a showstopper! Congrats on you early Christmas.
G
guitlouie
WOW is right!  I'm usually not a fan of gold hardware, but once again, your impeccable taste has found a winner!
-CB-
there is a shorty switchcraft that G uses, these can be had on the 'bay for about $12-14
NonsenseTele
Don't you have shame to tempt us with those nice guitars???  :icon_biggrin: :icon_jokercolor:
ibob74
Very very nice, and the correct orientation too. Is that one a keeper?
I'm thinking a clear gloss would look spectacular - what do you have planned?
- Lets see the back.
willyk
m4rk0 said:
I love it!!
What kind of neck will you put on it?
It's already there.  Bubinga/bubinga boatneck. 6130 wire, abalone dots, graphite nut and Variax headstock.
willyk
Here ya go ibob..Yup this one's a keeper for sure. I'm going to do it the same as the Korinakaster i.e. sand/sealer. brownstained grainfill then tung oil in thinned applications. The back is quite plain which is just what I wanted. The sides have some nice little swirls just to make it interesting but not enough to overpower the top.
kruneh
That is stunning.
Love the gold hardware and pups. The neck. The top. Everything.
A great idea, can´t wait for the final pics!
Ted
Lovely guitar Willy !  :eek:
Note thats a lefty so it must be for you!!!  :icon_scratch:
Look forward to seeing the finished article.
jackthehack
Nice, I've been think about doing an L5S; can you get a std. Gibson V-V-T-T control hole set drilled at factory with 2nd f-hole option, or do you have to just do a V-T? The bottom of the 2nd f-hole looks like it might be in the plane of the std. upper control hole routes?
willyk
I couldn't say for sure Jack. I ordered it without any holes as I hadn't decided what I wanted :dontknow:
