Rick
Epic Member
For your viewing pleasure ...
It plays like a dream,
The warmoth parts with their excellent fit are impeccable. The body shape is really comfortable. The gloss inferno flake finish is beautiful .. probably best seen in the pic of the horn. It pops! Highlights include the DiMarzio DP240 neck pickups, they are like the best tele neck pickups but with balls. The Freeway switching gets lots of sonic options. Great for Americana. Could play it all day. It's a pro guitar.
Total weight: 8 Lbs. 2oz
Thank you Warmoth! And everyone who helped along the way.
Warhead Guitar Neck
Construction Modern
Shaft Wood Quartersawn Maple
Fretboard Wood Indian Rosewood
Nut Width 1-3/4" (44mm) - Wide
Right / Left Handed Right-Handed
Neck Back Profile Wolfgang
Fretboard Radius 10" - 16" Compound
Number of Frets 21
Scallops None
Binding None
Fret Size & Material SS6150 - Wide & Tall (Stainless)
Tuner Hole Size Schaller/Modern Fender/Sperzel (25/64")
Inlay Shape Split Diamond
Inlay Material White Pearloid
Side Dots White Side Dots
String Nut Standard Nut - GraphTech White TUSQ XL
Mounting Holes Standard 4-Bolt
Neck Heel Shape Strat® Shape
Finish Vintage Tint Gloss
Jazzmaster® Replacement Guitar Body
Construction Chambered
Core Wood **Extra Light Poplar**
Lam Top Wood Alder
Control Cavity Top Rout
Neck Pickup Rout Humbucker
Middle Pickup Rout Humbucker
Bridge Pickup Rout Humbucker
F-Holes None
Jack Rout 7/8" (22mm) Side Jack Hole
Bridge Rout Type Hardtail
Bridge Rout Fender American Standard Strat® Flat Mount
Neck Pocket Shape Strat®
Body Contours Forearm Contour, Tummy Cut
Binding and Edge Decorations Pearloid Binding (Drop Top)
Battery Box None
Paint Category Flake
Inferno Flake
Gloss
Jazzmaster® Pickguard
Color / Material White Pearl
Right / Left Orientation Right-Handed
Neck Pickup Rout **Gibson Mini Hum**
Middle Pickup **Gibson Mini Hum**
Bridge Pickup **Gibson Mini Hum**
Bridge Cut Non-Jazzmaster® Tremolo or Hardtail Bridge
Controls Volume 1, Tone 1, Input Jack
Upper Switch Upper Blade Switch
Lower Switch None
Hardware and electronics from Warmoth
Neck Screws Color Stainless-Steel
Pickguard Screws Color Stainless-Steel
1/4" Jack, Mono
Football Side-Jack Plate Color Chrome
Flat-Top Knob Color Chrome x2
500K Audio Pot x2
Guitar String Ferrule x6 Color Chrome
Schaller S-Locks Color Chrome
Non-Warmoth Parts
Tuners: Hipshot Staggered Locking Tuners with UMP plate chrome
Buttons: Hipshot Hex Pearloid
Bridge: Callaham Am. Std Hardtail w/ 3 enhanced compensated brass saddles
Custom Neck Plate with pad
PUPS: DiMarzio Minihumbuckers DP 240x2 + DP241
tone control: .022 mfd cap
Treble Bleed on volume: 180pf
Toggle: Freeway 10 position
Miniswitch On/on 3dpt
Dress nut for miniswitch
Miniswitch tip: white
Case: Gator Jazzmaster. Modified with extra padding.
Strap: Sun Strap Red
Stings: D'Addario Nickel 10's
Warhead Guitar Neck
Construction Modern
Number of Frets 21
Scallops None
Binding None
Lam Top Wood Alder
F-Holes None
Battery Box None
Inferno Flake
Gloss
Lower Switch None
1/4" Jack, Mono
500K Audio Pot x2
Non-Warmoth Parts
